Author Topic: Tire size and fender width.  (Read 2677 times)
Offline rockman
  • Total likes: 284
  • Model and Year: 97 TJ and 03 Rubicon
Re: Tire size and fender width.
« Reply #12 on: May 19, 2017, 08:29:33 PM »
It does rub a little but it's not an issue. It's a great trade-off, still run stock flares on both TJs but Rubicon flares are 1" wider which works for 35s.
Offline BOHIC
  • Dysfunctional Veteran
  • Non Supporting Member
  • Total likes: 5
  • The patriot's blood is the seed of Freedom's tree.
  • Model and Year: 1989 Jeep Wrangler Sahara
« Reply #11 on: May 19, 2017, 08:18:32 PM »
If you're running a 33" or smaller tire you can buy a 10.5" tire that actually works better. Also, I run rims with 4.5" backspacing and that keeps them tucked in better.
How is that with full turn, do you rub
Offline rockman
  • Total likes: 284
« Reply #10 on: May 19, 2017, 07:32:06 PM »
Offline BOHIC
  • Total likes: 5
« Reply #9 on: May 18, 2017, 08:30:36 PM »
Thanks for the reply, guess I'll have to look into extending my fenders.  :-\
Offline Doc
  • 2002 Jeep TJ
  • Administrator, Webmaster, Treasurer
  • Club Founder
  • Total likes: 263
  • It's a Jeep thing... And it's WICKED expensive!
  • Model and Year: 99 Cherokee XJ Clasic, 99 Cherokee Sport, 99 TJ X, 02 TJ X, CJ7 and now another 2002 TJ X
« Reply #8 on: May 18, 2017, 04:11:18 PM »
as most have said, Maine is 100% coverage on tires, with that said, mine stick out 2.5 in front and 1.5 in the rear
they can pass all depends who inspects it, but also what Aaron said, even if it is inspected the police can stop you ..
your choise is .. to play nice with the inspection station and state you did it after inspection, they you pay the fine if they decide to give it to you
my inspection person knows that if I get stopped I will take the fine !!!
Enjoy the trails ... Tread Lightly, Respect the Landowner ... and Get Permission!
Offline yamaha225
  • Total likes: 355
  • Jeepin on a college budget
    • Maineiac Offroad
  • Model and Year: 1997 Jeep Wrangler
« Reply #7 on: May 18, 2017, 08:51:19 AM »
It's not just inspections you have to worry about. Cops can and will pull you over for having your tires stick out past the fenders. Gotta say that's one law that I agree with. I don't really want rocks and spray coming off your jeep and blasting me when I'm driving my daily.
'97 TJ, 4 really angry squirrels under the hood, AX-5, 31 MT/R-K's, 44:1 crawl ratio, 8000 Smittybilt X2O winch, Sanden OBA, 2.5 inch RC spring lift, Custom Fab Rear bumper, Ford 8.8 Rear Axle with 4.10's and Trac Lok Limit Slip, Dana 30 Front Axle with 4.10's and a Aussie Locker, Metalcloak Rear Upper Control Arms and Trackbar
Offline Jake
  • Total likes: 7
  • Model and Year: 1999 Jeep Cherokee XJ
« Reply #6 on: May 18, 2017, 06:39:42 AM »
There's no tire size limit, but there is a vehicle height to weight limit. Also the most current inspection manual states the entire tread must be covered. That being said, as an inspection technician at a dealership when I worked there, as long as there was at least an attempt to cover the tread, I would pass the vehicle. But if a truck or jeep is running around with 6 inches of uncovered tread coming in for a sticker they would get laughed at.
Offline Netorts
« Reply #5 on: May 18, 2017, 06:14:53 AM »
There are a ton of keeps on the road with 12" wide tires and many have aftermarket fenders that do not cover the full tire.   They all got inspected somewhere I would imagine. I have 35 x 12.5" tires with bushwhacker flares (they don't cover, ) and a dealer ship inspected it last year..,.,,
Sent from my iPhone using Tapatalk
Offline djljeep
« Reply #4 on: May 17, 2017, 11:10:03 PM »
From (a only moderately out of date, but still relevant) inspection handbook.
Offline djljeep
« Reply #3 on: May 17, 2017, 11:03:12 PM »
Just checking to see if there has been a update since the stickied post.
I'm fairly sure inspection requires 100% coverage of the actual tire tread.  I posted on the facepage about it a couple weeks ago.  Standby for actual language...
Offline BOHIC
  • Total likes: 5
« Reply #2 on: May 17, 2017, 10:52:28 PM »
Offline BOHIC
  • Total likes: 5
« Reply #1 on: May 17, 2017, 09:18:07 PM »
Does anyone know if there is a width limit on tires sticking out past the fenders. I want to get a 12" wide tire but I don't want to have huge fenders to cover them. If someone could chime in on the inspection process with that I would appreciate it.
