Author Topic: Electrical problems, anyone good with this stuff?  (Read 925 times)
Offline Grimm
  • Self taught Trained Professional
  • Total likes: 117
  • Too. Many. Projects.
  • Model and Year: Wouldn't you like to know
Re: Electrical problems, anyone good with this stuff?
« Reply #5 on: November 21, 2016, 10:43:28 PM »
Common problem ... My 2000 did the same or would sometimes feed the left blinker circuit ... If you wiggle the blinker switch arm while it is happening does it operate normally until the next time? ... Mine was the multifunction switch (I won't say what I normally call it) LOL
What could POSSIBLY go wrong?
« Reply #4 on: November 19, 2016, 06:36:44 AM »
I'd guess there's bad connection at the plug. Possibly the ground is toast.
I'd start testing voltages at the bulb and work my way towards the fuse box.
Offline djljeep
« Reply #3 on: November 17, 2016, 07:47:50 PM »
When you step on the brake light stays on or no light at all?
  • Total likes: 958
« Reply #2 on: November 17, 2016, 07:43:05 PM »
It may be a short. It may also be a bad ground. I would pull the lense off of the left rear and look at the metal fixture that holds the bulb in. That may be corroded and causing your bad ground
Offline JeepDad1994
  • Total likes: 2
  • Model and Year: 2000 Jeep Wrangler 2.5L 5spd new project to play with
« Reply #1 on: November 17, 2016, 06:43:50 PM »
i owe a 2000 Jeep wrangler. when i put my left blinker on and foot on the brake, the blinker will pause and stop, when i let my foot off the brake, the blinker countinues to blink. i havnt checked anything on it yet, my guess would be a short maybe? any help is appriciated! thank you!
