Author Topic: black 87 yj  (Read 17417 times)
  • Non Supporting Member
Re: black 87 yj
« Reply #22 on: October 13, 2015, 07:08:06 PM »
Very cool!
Wooly
Offline ncasey207
  • Total likes: 81
  • Model and Year: 1987 yj
Re: black 87 yj
« Reply #21 on: October 13, 2015, 02:37:37 PM »
Few more upgrades installed a viair system and a rear end with an Arb locker in it
Offline ncasey207
  • Total likes: 81
Re: black 87 yj
« Reply #20 on: August 31, 2015, 07:51:39 AM »
Picked up the transmission and motor 4 inches and replaced the motor mounts with a different design
Offline Grumpy
  • Total likes: 90
    • Facebook
  • Model and Year: Wrangler 2004
Re: black 87 yj
« Reply #19 on: July 19, 2015, 04:48:59 PM »
That's what they do in Virginia beach, bed line the whole jeep body.
It ain't Easy being Easy!
Offline JeepGeek
  • Total likes: 82
  • Model and Year: 04 LJ Unlimited. 4" lift and 33" tires.
Re: black 87 yj
« Reply #18 on: July 19, 2015, 10:58:18 AM »
How much would it cost to get my whole jeep done? I am really thinking about it.
Save a life, Give blood.
Offline ncasey207
  • Total likes: 81
Re: black 87 yj
« Reply #17 on: July 19, 2015, 08:42:02 AM »
Been also workin on a new tub got it all done it's been painted inside and out with spray in bed liner from work I'm pretty happy with he way it came out now just need to get it swapped over
Offline ncasey207
  • Total likes: 81
Re: black 87 yj
« Reply #16 on: July 19, 2015, 08:38:10 AM »
Had some transmission problems had to replace It. I replaced the sm465 4 speed with a nv4500. Motor man was a great help in getting the sm465 bell housing installed on the nv4500 and it was a bit of trouble getting the for np205 transfercase mounted to the back of it but I got it all in and works great glad to have 5 gears instead of 4
Offline ncasey207
  • Total likes: 81
Re: black 87 yj
« Reply #15 on: March 07, 2015, 05:29:10 PM »
Not of that one me and another guy are building that one bill start takin pics this week it's an 82 cj bran new frame and a wrangler tub
74Cj5
  • Guest
Re: black 87 yj
« Reply #14 on: March 07, 2015, 04:29:52 PM »
Oh ok.  Got any pics?
parts are ordered advanced adaptors 4l60 to np231 advanced adaptors motor mounts and also got a lokar floor shifter comin need to collect all the parts before i start taking it all apart still need to order a sye and fuel system parts getting closer
When I put the 5.3 and 4l60E dana 300 in a yj  the driveshaft hit the transmission pan.  I replaced the dana 300 with the 4 speed atlas.  You probably have already looked into that.  Just my 2 cents
How did you fix the problem?  The Atlas was wider then the Dana 300 so it was a easy fix for me.
Offline ncasey207
  • Total likes: 81
Re: black 87 yj
« Reply #13 on: March 07, 2015, 04:19:21 PM »
Haven't got that far in that build yet starting again on it this coming week if I can't make it work I'll probly put a 205 in it
74Cj5
  • Guest
Re: black 87 yj
« Reply #12 on: March 07, 2015, 01:57:45 PM »
Offline ncasey207
  • Total likes: 81
Re: black 87 yj
« Reply #11 on: March 07, 2015, 01:16:41 PM »
Ya we had that problem on a 700r4 with a Dana 300 with a passenger side drop was the one you had flipped for drivers drop? Or was it passenger?
« Last Edit: March 07, 2015, 03:25:49 PM by ncasey207 »
74Cj5
  • Guest
Re: black 87 yj
« Reply #10 on: March 06, 2015, 09:36:39 AM »
Offline ncasey207
  • Total likes: 81
Re: black 87 yj
« Reply #9 on: March 05, 2015, 08:58:37 PM »
Re: black 87 yj
« Reply #8 on: February 27, 2015, 06:51:40 PM »
Wooly
Offline ncasey207
  • Total likes: 81
Re: black 87 yj
« Reply #7 on: February 26, 2015, 09:23:22 PM »
Pic
Offline ncasey207
  • Total likes: 81
Re: black 87 yj
« Reply #6 on: February 26, 2015, 08:31:36 PM »
so it time to try this again the carbed 350 worked well has plenty of power not much good for steep inclines. so it time for some fuel injection so every thing is comin out and a 5.3 4l60 out of a 01 silverado is going in headers just showed up today more parts to come in the next few weeks
  • Total likes: 959
Re: black 87 yj
« Reply #5 on: August 12, 2014, 09:01:30 PM »
That's nice!
Offline ncasey207
  • Total likes: 81
Re: black 87 yj
« Reply #4 on: August 12, 2014, 08:39:06 PM »
its gettin there still have alot of work to do but most of the parts have showed up and it time to assemble and build some exaust plan is to drive it by the end of the weekend
[attachment deleted by admin]
Offline ncasey207
  • Total likes: 81
Re: black 87 yj
« Reply #3 on: August 03, 2014, 10:58:08 PM »
made some progress today got the tranny and transfer dug out and cleaned ready to be painted (there not clean in the pics lol) also went and picked the motor up and started taking it apart to swap the heads and change the rod bearings since the new heads will up the compression. also worked on getting the frame fixed up and welded the new crossmember to the front of the frame so that i can do away with the round tube factory one to set the winch down in the frame rails. the crossmember is also the front bumber. there is another crossmember aswell that is to mount the motor on i need to weld that in but have to get the motor set in so i make sure its where i want it to be. shouldnt be long and i can drive it again once all the parts so up for it
Offline ncasey207
  • Total likes: 81
Re: black 87 yj
« Reply #2 on: July 30, 2014, 09:46:04 PM »
found out that something went very wrong with cylinder 5 not sure what happen with the rod but i no its broke due to the hole in the side of the oil pan but i have made some progress with the dissasemble the motor is out now will start cutting brackets off the frame tomorrow night and get ready for por15 the frame and fix my rust issues wont be long it will be time to wheel again
Offline ncasey207
  • Total likes: 81
black 87 yj
« Reply #1 on: July 27, 2014, 10:45:14 PM »
so i blew the motor in my yj today so now its time to start the small block chevy build. Heres the list so far for whats to come in
the next coulpe weeks
engine
95 350 4 bolt main
98 vortec heads
summit intake
holly 650 carb
HEI distibutor
tranny and transfer
85 sm465
78 ford np205 with chevy input shaft to drop on the drivers side
np205 clocking ring form northwest fab
thats all for now next will be ford nine inch for the rear and dana 44 for the front
also have a rusty frame issue that i will fix while the front clip is off and a custon front bumper with a recessed winch mount between the frame rails
