Author Topic: Motor Man  (Read 24540 times)
Offline cweemanrun
  • I know ive broke that and if i haven't I will
  • Total likes: 7
  • Model and Year: 2003 jeep wragler/custom weeman built buggy
Re: Motor Man
« Reply #44 on: March 09, 2013, 05:54:14 PM »
Looking good
Offline Motor Man (Bill)
  • Total likes: 16
  • RTI Ramp Front 1382.98
  • Model and Year: 2003 TJ with a couple mod's / 2000 2 door XJ
Re: Motor Man
« Reply #43 on: March 09, 2013, 04:23:33 PM »
 the brackets are all weld on I need to have the coilovers before welding
« Last Edit: March 09, 2013, 07:45:40 PM by Motor Man »
Owner of Olamon off road park
Pass at own risk!
Motor Man
« Reply #42 on: March 09, 2013, 03:22:48 PM »
Very cool.  Liking the square tube.  Where is the head of the bolt that ties your control arm to the frame?  Those H tires are a new tread pattern? Nice looking work.
  • Total likes: 16
Re: Motor Man
« Reply #41 on: March 09, 2013, 02:46:02 PM »
The tire is 37" BFG off a Hummer
The axle is stretched forward 3 to 4" probably going to set it at 3"
[attachment deleted by admin]
« Last Edit: March 09, 2013, 02:58:10 PM by Motor Man »
Pass at own risk!
  • Total likes: 16
Re: Motor Man
« Reply #40 on: March 09, 2013, 02:29:19 PM »
Some photos of the 44 and 3 link
Pass at own risk!
Re: Motor Man
« Reply #39 on: February 26, 2013, 11:11:57 AM »
From my understanding, you have to move all of that stuff when you install 2.5 ton drop-in's with double coil-overs.
:D
Motor Man
« Reply #38 on: February 25, 2013, 05:51:50 PM »
I like the sound of that
Offline MtnClimber
  • Associated Clubs
  • Total likes: 46
  • Ready to Explore!
  • Model and Year: 01 Tacoma DC
Re: Motor Man
« Reply #37 on: February 25, 2013, 04:16:31 PM »
That's alotta work for a Hemi swap  8)
www.northeastoverland.org
"Arguing with a fool proves there are two" ~ Doris M. Smith
SUPPORT YOUR LOCAL FIRE DEPARTMENT
  • Total likes: 16
Re: Motor Man
« Reply #36 on: February 25, 2013, 12:17:54 PM »
The old girl's not looking to good right now :( T-case is out, trans is out, exhaust is off, gas tank is out, no axles and no suspension, front is all apart, no tires. :-\ :-X
Pass at own risk!
housew
  • Guest
Re: Motor Man
« Reply #35 on: February 18, 2013, 12:48:24 PM »
i really like that pitman arm  :o
Offline rockman
  • Total likes: 282
  • Model and Year: 97 TJ and 03 Rubicon
Re: Motor Man
« Reply #34 on: February 17, 2013, 12:30:24 PM »
Nice!
  • Total likes: 16
« Last Edit: February 16, 2013, 10:34:37 AM by Motor Man »
Pass at own risk!
Motor Man
« Reply #32 on: February 13, 2013, 05:42:45 PM »
Cool, ar ar
  • Total likes: 16
Re: Motor Man
« Reply #31 on: February 13, 2013, 12:28:19 PM »
My new Ford 9" I plan on cutting it down and making it a full floater.
The son's Dana 60HP is in the back ground.
Pass at own risk!
  • Total likes: 16
Re: Motor Man
« Reply #30 on: February 13, 2013, 12:20:00 PM »
Dana 44HP build update
Photo 1 heating the inner C to install it has a .003 fit and it will be welded.
photo 2 the C's installed and still setting in the jig with the c's set at 18deg's with the pinion at 0 I plan on having the ball joints set at 7deg and the pinion around 11deg not going to weld it till i check it under the Jeep.
Photo 3 is my built in axle seal it will have two o-rings and a grease fit between them to pump grease in.
I still need to mock it up under the Jeep and tack the brackets on then bring it back to the shop to weld everything with the big welder.
« Last Edit: February 13, 2013, 12:32:21 PM by Motor Man »
Pass at own risk!
  • Total likes: 16
Re: Motor Man
« Reply #29 on: February 10, 2013, 09:49:12 PM »
What in the heck are you up to?.?
I'm turning it into a CJ :P :-X
You started with a TJ but after you stretch that thing it might be a BJ or maybe a MMJ. Or maybe you really want an XJ. (Just kidding). Looks like an ambitious project, you definitely have a unique Jeep.>
I would like to have an XJ :nuts:  :-X
Pass at own risk!
Offline rockman
  • Total likes: 282
Re: Motor Man
« Reply #28 on: February 10, 2013, 08:35:01 PM »
  • Total likes: 16
Re: Motor Man
« Reply #27 on: February 09, 2013, 10:40:24 PM »
Pass at own risk!
Motor Man
« Reply #26 on: February 09, 2013, 09:32:40 PM »
  • Total likes: 16
Re: Motor Man
« Reply #25 on: February 09, 2013, 07:58:51 PM »
Two days into the tear down going to do some cutting tomorrow. :fear: :o
Also need to remove the steering box for the stretch.
« Last Edit: February 09, 2013, 08:10:07 PM by Motor Man »
Pass at own risk!
  • Total likes: 16
Re: Motor Man
« Reply #24 on: November 15, 2012, 01:09:22 PM »
40 ton to press the tube from inner C
Pass at own risk!
Motor Man
« Reply #23 on: November 14, 2012, 10:19:48 AM »
Jealous
  • Total likes: 16
Re: Motor Man
« Reply #22 on: November 14, 2012, 07:10:20 AM »
This is what a 1/2 hour in the saw will do to a Dana 44 LOL
 :face: :face: Point of no return  :face: :face:
Pass at own risk!
  • Total likes: 16
Re: Motor Man
« Reply #21 on: November 08, 2012, 05:27:19 PM »
I'm still looking at 4 link setups for the back I plan on using 2" sq tubing for the arms
Why square?  Any particular reason?  Easier to bend/work with than the round?
Tough, Cheap, Easy to work with, you can get pre made inserts and most important I already have some ;)
Pass at own risk!
Re: Motor Man
« Reply #20 on: November 08, 2012, 08:31:48 AM »
  • Total likes: 16
Re: Motor Man
« Reply #19 on: November 07, 2012, 02:27:09 PM »
Axle going for a 1/2 hour ride in the parts washer. water temp is 180F 24 nozzles @ 195 psi each
Pass at own risk!
  • Total likes: 16
Re: Motor Man
« Reply #18 on: November 07, 2012, 04:43:57 AM »
Plan on going with this
http://www.4ws.com/super-88-axle-system-for-ford-8-8-inch.html
Going to setup a different 8.8 and sell the one in mine. going with a 4 link i think. I would like to be 62" wide when it's done.
That's a slick setup Bill.  Have you decided where you're sourcing brackets from?
Any thoughts on your arm-geometry yet?
Still looking but I like the stuff from Ruff stuff. Evo & T&T
Pass at own risk!
Re: Motor Man
« Reply #17 on: November 07, 2012, 12:17:59 AM »
  • Total likes: 16
Re: Motor Man
« Reply #16 on: November 06, 2012, 04:10:30 PM »
i doubt a 4.0 will ever be able to break that no matter what you do to it.
LOL :innocent: :
« Last Edit: November 15, 2012, 12:24:05 PM by Motor Man »
Pass at own risk!
housew
  • Guest
Re: Motor Man
« Reply #15 on: November 06, 2012, 03:27:10 PM »
good find, that super 8.8 kit solves everything for $600.
widens it almost 2 inches, ditches the c-clips, gets you alloy shafts, gets you giant wheel bearings, and lets you choose 5x4.5 or 5x5.5.
that's a bargain for all the improvements it makes, and i doubt a 4.0 will ever be able to break that no matter what you do to it.
  • Total likes: 16
Re: Motor Man
« Reply #14 on: November 06, 2012, 12:08:59 PM »
Disassembled the long side and confermed the tube is 3" with a 1/2" wall  :yes: :clap:
Pass at own risk!
  • Total likes: 16
Re: Motor Man
« Reply #13 on: November 05, 2012, 06:36:19 PM »
very nice,
you swapping the 8.8 over to 5x5.5? If so can you just drill in a second bolt pattern in the stock shafts or do you need to order aftermarket guys or are you going to run 5x4.5-5x5.5 adaptor spacers?
going for 60" wms-wms or a little wider?
Pass at own risk!
  • Total likes: 16
Re: Motor Man
« Reply #12 on: November 05, 2012, 06:27:43 PM »
Any idea how heavy that is?
325 lbs with the brakes it has 3" tubes
« Last Edit: November 05, 2012, 06:29:14 PM by Motor Man »
Pass at own risk!
Motor Man
« Reply #11 on: November 05, 2012, 04:41:19 PM »
Well there.  That should do it!
housew
  • Guest
Re: Motor Man
« Reply #10 on: November 05, 2012, 12:01:46 PM »
very nice,
Offline MtnClimber
  • Associated Clubs
  • Total likes: 46
  • Ready to Explore!
Re: Motor Man
« Reply #9 on: November 05, 2012, 07:46:11 AM »
  • Total likes: 16
new project
« Reply #8 on: November 05, 2012, 06:40:00 AM »
My new winter project Ford high pinion Dana 44R Has 5:13 gears and a mini spool lockout hubs.
The Plan ;)
Cut it down
Truss it
Install axle tube seals.
install 1/4 x 2" AR-400 wear plate (rock strip on bottom of housing)
« Last Edit: February 23, 2013, 08:24:17 AM by Motor Man »
Pass at own risk!
  • Total likes: 16
Re: Motor Man
« Reply #7 on: September 26, 2012, 09:44:30 PM »
I've done allot of stuff to my Jeep lately  ;)
installed hard top
new roof sliders with jack and shovel mount
installed a different type of long arm bushings
repaired the track bar mount (frame side)
grooved the tires
added valve stem protectors and new stems
new brakes
new 170 max amp alternator
new ford explorer fan and clutch
new right side mirror with no convex glass
new CB mount, new cable and 5' antenna (ordered a new CB also)
Pass at own risk!
Offline Doc
  • 2002 Jeep TJ
  • Administrator, Webmaster, Treasurer
  • Club Founder
  • Total likes: 263
  • It's a Jeep thing... And it's WICKED expensive!
  • Model and Year: 99 Cherokee XJ Clasic, 99 Cherokee Sport, 99 TJ X, 02 TJ X, CJ7 and now another 2002 TJ X
Re: Motor Man
« Reply #6 on: October 31, 2011, 10:33:57 AM »
the videos are a great touch ... love it!!
Enjoy the trails ... Tread Lightly, Respect the Landowner ... and Get Permission!
  • Total likes: 16
Re: Motor Man
« Reply #5 on: October 23, 2011, 08:20:18 AM »
Pass at own risk!
  • Total likes: 16
Re: Motor Man
« Reply #4 on: October 23, 2011, 08:08:42 AM »
Pass at own risk!
  • Total likes: 16
Motor Man Wheeling big rock @ SH
« Reply #3 on: October 23, 2011, 07:32:13 AM »
http://youtu.be/7iJnB13nCdcWheeling big rock @ SH
Pass at own risk!
Re: Motor Man
« Reply #2 on: June 03, 2011, 10:51:37 PM »
Don't forget to mention it has A/C! :D
[edit: Removed taunting comments :D ]
« Last Edit: June 04, 2011, 09:26:58 AM by Lucifer »
  • Total likes: 16
Motor Man
« Reply #1 on: June 03, 2011, 07:49:00 PM »
2003 TJ, 4 Liter, 5 Speed, 97K miles
Air cond, Cruise, Tilt, CD player
Fiberglass hood
Class 2 receiver hitch
1" R/C seat riser
Suspension
6" Rough Country long arm
Shocks R/C 2.2
Bar pin eliminators
1-1/4" body lift
1-1/2" motor mount lift
Custom bump stops
Tires & Wheels
Pro comp Xterrain 315 x 75R x 16 Radials
Maxxis Creepy Crawler 35 x 12.50 x 16 Bias
Pro comp steel wheels
Innerairlock bead locks
Centramatic  wheel balancers
Front Axle
Dana 30
410 G2 gears
Auburn Ected electric locker
USA alloy axle shafts
USA axle tube seals
Currie Upper control arm Johnny joint kit
Crown brake lines
R/C quick disconnects
Teraflex right side knuckle mount sway bar bracket
R/C differential guard
R/C  adjustable track bar
R/C Track bar relocation bracket
Yoke with u-bolts
1" wheel spacers
Steering
Rock Krawler X factor (over the knukle)
R/R drop pitman arm
Rear Axle
 Ford 8.8
410 gear
31 spline axle Shafts
Heavy duty bracket kit
Crown brake lines
Currie emergency brake cable kit
Aussie locker
Solid differential cover
Sky Jacker adjustable  rear track bar
Tom Wood's drive shaft
Gold seal u-joints
1-1/2" wheel spacers
Transfer Case
NP 231
Teraflex shift bracket
Teraflex 2 wheel drive low kit
Rugged Ridge slip yoke eliminator
Custom cross member
Armor
Custom boat sides 36" under the rock slide with 10 psi tire pressure
Custom Belly up skid with only 1 inch drop
Rock sliders
Custom engine oil pan skid
Custom radiator skid
R/R steering box skid
Front fenders Genright G3 fenders with 6 inch flare with louver side panel
custom 5 inch  rear tube  fenders
1/8 inch diamond plate crusher corners
Front bumper R/R
Back bumper R/R
Custom aluminum cargo area cover
Lights
LED front blinkers
LED marker lights
Head lights "Round eyes"
Recovery (This stuff is only used for wagon recovery)LOL
Front winch Smittybilt 10,000lb
Rear winch Warn 8,000lb with custom mount
Snatch block
30ft 30,000lb snatch strap
3ft 6ft 20ft straps
150' steel cable
High lift jack
Hydraulic jack
Shackles
Rear meat hook
Electronics
Cobra CB
Uniden CB with 4' antenna
Garmin GPS
Delorme PDN 40 GPS
Kodak water proof cameras
Go video water proof camera ( for under jeep)
Tools and Equipment
Enough tools to repair most field problems
Shovel
Electric air compressor
450ft lbs cordless impact wrench
Safety
First aid kit
2 fire extinguishers
Spare parts (I have this stuff so Lucifer can make it back) >:) LOL
Belt
Plugs
U-Joint
Valve stems
Starting Fluid
Bolt kit
Spare Key
Spare lug nuts
« Last Edit: July 19, 2012, 09:58:23 PM by Motor Man »
Pass at own risk!
