Author Topic: Do you weld? READ ME!  (Read 4024 times)
Offline Doc
  • 2002 Jeep TJ
  • Administrator, Webmaster, Treasurer
  • Club Founder
  • Total likes: 263
  • It's a Jeep thing... And it's WICKED expensive!
  • Model and Year: 99 Cherokee XJ Clasic, 99 Cherokee Sport, 99 TJ X, 02 TJ X, CJ7 and now another 2002 TJ X
Re: Do you weld? READ ME!
« Reply #8 on: May 01, 2010, 07:45:45 AM »
never though of the fan ... thats a great idea ... thanks monkey
Enjoy the trails ... Tread Lightly, Respect the Landowner ... and Get Permission!
monkey
  • Guest
« Reply #7 on: May 01, 2010, 07:34:45 AM »
yes this is one thing you learn in welding class. at work ive notced that when i weld while someone else is using brake clean 50 feet away it creates a distinctive smell. we use non chlorinated brake kleen also. i know its not right but i use brake clean to degrease and then blow it off with compressed air n let sit most of the bad juu juu will evaporate.
also use a small fan to create a cross breeze to push the smoke away from your hood as the smoke is bad enough to add up n kill ya also. not a big breeze though it will push your shielding gas away...
Offline Grimm
  • Self taught Trained Professional
  • Total likes: 117
  • Too. Many. Projects.
  • Model and Year: Wouldn't you like to know
« Reply #6 on: April 21, 2010, 08:27:04 PM »
guess i wont be using break kleen on anything i weld!!!  :fart:
just make sure you avoid any brake cleaner that contains chlorine I only use non-chlorinated cleaner so it isn't as big a deal but as with any chemical you NEED to read the label and if available the MSDS sheet before using torches welding equipment etc.
What could POSSIBLY go wrong?
hoodup
  • Guest
« Reply #5 on: April 21, 2010, 07:28:36 PM »
« Reply #4 on: April 21, 2010, 08:36:46 AM »
I never really thought about what burns when I'm welding.  Paint, grease, brake fluid, whatever... if I can get an arc, I'll weld.  I figure the heat will burn off whatever's in the way and it always does.  I always assume that because I'm in an open-air environment (usually) that I'm not breathing in anything THAT harmful (at least not in the limited quantities that I am exposed to.)
Reading that this guy nearly died after breathing in a tiny little 'poof' of smoke in such limited quantity (I'm sure most of us has seen that before!) scared me big time!
I knew that the special radar-reflective paint (think it's called C.A.R.T. paint) that the military uses is super-nasty when it burns.  The sergeants taught me that at U.T.C. where I learned to weld and torch-cut.
I intend to be a bit more careful of what I "Burn Through" when I'm welding from now on!
Offline kdukes4
  • Total likes: 0
  • 53.23 crawl ratio
  • Model and Year: '04 TJ
« Reply #3 on: April 21, 2010, 07:54:54 AM »
yikes.
I Love My Jeep!
Offline Grimm
  • Total likes: 117
« Reply #2 on: April 21, 2010, 06:33:16 AM »
very informative article
« Reply #1 on: April 21, 2010, 05:19:10 AM »
Read this article ASAP if you weld!!!
http://www.brewracingframes.com/id75.htm
